Hello Guest it is November 11, 2026, 11:14:13 PM
Author Topic: Microcarve  (Read 8996 times)
Microcarve
« on: May 30, 2013, 06:33:05 PM »
Anyone out there using Microcarve?
I know that it is a lazy way to generate G Code but it seems to do the trick with the exception that when I load it onto my system using Mach3, the size is way too small.
I am new to the CNC routing game as it is a new hobby.
I am also looking for G Code that will allow me to produce Old English lettering.
Thanks for the support
Re: Microcarve
« Reply #1 on: May 30, 2013, 09:36:15 PM »
Are you possibly generating g code in mm when you want it to be inches or maybe exporting g code for inces but are set up to run mm?  If you command a move of 1 from MDI, does it move 1mm or 1 inch?
Try adding a G20 as the first line of code then change it to a G21 and see the difference.
