Hello Guest it is November 13, 2026, 05:12:25 PM
Author Topic: Error triggered - Art Code: 8877  (Read 9768 times)
« on: May 27, 2013, 10:56:07 AM »
I can start a thread and output serial data constantly without problems.
As soon as I do a serialPort->ReadByte() or serialPort->Read(buf, 0, 1) - I get an error on start up of Mach.  It's "Art Code: 8877".
I've tried it both with blocking reads and with a timeout.
Anybody have any insights on "Art Code 8877"?
Re: Error triggered - Art Code: 8877
« Reply #1 on: May 28, 2013, 02:09:50 AM »
I'd still like to understand what's going on - but I've worked around it in a slightly more processor intensive way.
Instead of blocking on the read, I did the following.......
void ReadSomeBytes(array<unsigned char>^ buffer, UInt16 offset, UInt16 count)
   while ((MG::thcData.thcSerial->BytesToRead < count))
      // Kill the thread if requested.
      if (MG::thcControl.hariKari)
         ExitThread(0);
      // Didn't get killed, so sleep a little
      Sleep(5);
   // Read the bytes.
   MG::thcData.thcSerial->Read(buffer, offset, count);
 ("hariKari" is a boolean flag that the plug-in uses to signal the serial input processing thread to gracefully shut down.)
