Hello Guest it is November 13, 2026, 09:44:33 AM
Author Topic: Machine movement  (Read 37050 times)
Re: Machine movement
« Reply #10 on: May 27, 2013, 05:27:22 AM »
Hey Hood, leave Tweakie alone as he had the same spelling teacher that I had.  :)
BTW Tweakie , maybe "in" instead of "if" .  :D
  •  9,377 9,377
« Reply #11 on: May 27, 2013, 05:31:53 AM »
 ;D ;D ;D
« Reply #12 on: May 27, 2013, 05:36:05 AM »
Tweakie, I already knew that, but thanks for the heads up.
Only one way to Get-er-Done......Do-er-Right!
« Reply #13 on: May 27, 2013, 09:18:53 AM »
Yes Robert, overlook Hood's modesty.  He has been at this for a long time......... a very long time.......... he is wise like father time for a good reason........ they were born in the same year.  ;D  I'd love to have a nickle for every bit of good solid advice Hood has given.
Rich and Tweakie are fine ones too.  In fact we have a very good group period and your part of that so pat yourself on the back too.  :)
I spell checked this twice too BTW and it said it was good all both times........  :P
« Reply #14 on: May 27, 2013, 10:49:27 AM »
Sounds like a good crew.
Hood, I changed the pins and; I double check the Plasma window and all works fine.  I changed the pin #'s to match and: The L arrow moves the X to the the R, the R to the L. The up axis moves down and visa versa.  The A does not move. I also enabled the #2 port and changed the address to the same as plasma.
Is there a check to turn the slave on?
I tried to reverse the numbers, thinking that would move them in the opposite and nothing moved.
Don't know where to go next.
  •  9,377 9,377
« Reply #15 on: May 27, 2013, 11:28:26 AM »
I am not an expert at this because I have never had occasion to actually do it but…
In Motor Tuning make the settings exactly the same for both the Y and A axes and save the settings for each.
In General Config uncheck the A-Axis so it makes the A axis Linear.
In Slave Axis select Y to A then restart Mach3.
You should now have both these axes slaved.
« Reply #16 on: May 27, 2013, 12:38:03 PM »
And Brett and my Granddad were school buddies :)
« Reply #17 on: May 27, 2013, 12:39:23 PM »
To change the direction an axis moves you change the active state of the Dir pin for that axis (Ports and Pins, Motor Setup page)
« Reply #18 on: May 27, 2013, 02:50:30 PM »
we're getting there.
The 3 axis and the A are working......Yea.
The only thing is, when I run my plasma, The motors have a good solid sound.  When I run the Mill they have a weaker/whiney sound.
I will run a test later to make sure I got it.
Is there any problem with the sound?
« Reply #19 on: May 27, 2013, 02:58:43 PM »
Think you have different motor tuning values for each profile, if its the same machine then I would expect each to be the same between profiles.
