Hello Guest it is October 24, 2026, 08:45:24 PM
Author Topic: tool request light  (Read 13191 times)
tool request light
« on: May 25, 2013, 02:04:10 PM »
I do manual tool changes and use the m06 code and in general config have it stop spindle and wait for restart.  All that works great but how to I either edit the macro to turn on an output to add a tool requested light like the one that flashing on the screen?  I need a remote light and have a few extra outputs available on my breakout board.  Or if easier is there a m code the turns on outputs or can I make one?
Don
Re: tool request light
« Reply #1 on: May 25, 2013, 05:28:13 PM »
A brain would be the easiest way, just have it look at LED 806, pass signal and output to whichever output you wish. Screenshot below is using output 1.
« Reply #2 on: May 27, 2013, 10:22:26 AM »
OK, I guess I need to do a little more research because I haven't a clue where to start with that.  I never did anything with marcos and just use the program as is.
Don
« Reply #3 on: May 27, 2013, 12:49:51 PM »
Ok as said a Brain would be the easiest, a brain is not a macro and is much easier to do if you do not know VB.
Go to Operator menu... wait a minute I posted some instructions yesterday to someone so to save typing I will post a link in a few minutes.
« Reply #4 on: May 27, 2013, 12:51:41 PM »
Ok look at this post, it will let you see how to do a Brain. You will just be using different options, ie similar to the ones above.
http://www.machsupport.com/forum/index.php/topic,24660.msg174494.html#msg174494
« Reply #5 on: May 27, 2013, 07:30:12 PM »
Thanks alot is works, didn't at first but I forgot to check the enable box.
Don
« Reply #6 on: May 28, 2013, 02:26:49 AM »
