Hello Guest it is October 23, 2026, 06:53:59 PM
Author Topic: Confused in Mach 2 enable pins config,it's mapping to XYZ or not?  (Read 39585 times)
Re: Confused in Mach 2 enable pins config,it's mapping to XYZ or not?
« Reply #20 on: August 04, 2009, 05:40:38 AM »
You cant as far as I know, that is a function that most stepper drives have internally (current reduction) so if your drives dont have that then afraid you are out of luck as far as I know.
« Reply #21 on: August 04, 2009, 07:05:30 AM »
Thanks anyway.
It seems that I dont have access to STEP and DIR signals in VB
http://www.machsupport.com/MachCustomizeWiki/index.php?title=VB_Constants_for_Signal_Names
is that true?
or if not how can i access them
« Last Edit: August 04, 2009, 07:14:37 AM by manmardam »
**Even a clock that does not work is right twice a day**
vmax549
« Reply #22 on: August 09, 2009, 07:20:40 PM »
YOu cannot do what you are asking. Mach is a machine controller IT controls the step and direction outputs not you.
Your problem seems to stem from a VERY bad drive design. Redesign the drives to industry standards and your problem of overheating will go away.
You can certainly control the enable signals BUT nowhere near fast enough to use as a heating control mechanism. You would loose control of the output pulse stream and loose steps every time you tried to start movement.
Mach was not designed to correct BAD design flaws in drive controls.
Sorry, (;-) TP
« Reply #23 on: August 25, 2009, 04:19:11 AM »
I solve this problem with microcontroller
