Hello Guest it is November 26, 2026, 04:04:04 PM
Author Topic: ARC not OK  (Read 8759 times)
ARC not OK
« on: May 19, 2013, 01:18:08 PM »
I do not have a ARC ok on the Mach 3 screen or the Texas Micre 301d when I am running.
I was getting a pierce but no movement. The pierce would last until I shut it off on the Mach screen.  I shut off the THC on the Mach screen and I began cutting again. However, I do not get an ARC OK signal at the THC or the ach screen.
The good news is I am cutting as well as ever..
Texas Micro suggested it is the torch (TD A40). ?????? At their suggestion I am going to run the test boards again.
I do have a 2nd issue and will post it separately.  This issue is dealing with my feed speed not changing, on the Mach screen with a new g-code.
Any help will be greatly accepted.
Thanks, Bob
Only one way to Get-er-Done......Do-er-Right!
Re: ARC not OK
« Reply #1 on: May 21, 2013, 06:42:55 PM »
Put an ohm meter on pins 12 and 14 on your TD automation cable.  That will tell you if it's the plasma.  With a good arc, you should see continuity between pins 12 and 14.
