Hello Guest it is November 13, 2026, 12:22:49 PM
Author Topic: Tool Change won't apply  (Read 8701 times)
« on: May 18, 2013, 08:17:26 AM »
Hi all,
I'm sure this is covered somewhere, but I couldn't find it...
I have an ATC, but sometimes I just want to manually release the old tool and insert the new tool by hand instead of running an actual tool change routine.  When I go to the MDI and input the new tool number (and press enter) it appears to know it has the new tool.  However, when I start running g-code it thinks it needs to do a tool change.  Example:
- Tool 1 is already loaded from previous g-code.
- Manually remove tool 1 and insert tool 2.
- in MDI, enter Tool Number: 2, press enter.
- Call up g-code, which has m6 t2 at the beginning.
- Machine jogs to change position to park t1 and then pickup t2.
What am I missing?
Re: Tool Change won't apply
« Reply #1 on: May 18, 2013, 01:24:46 PM »
You will really need to write something in your toolchange macro so that it just ignores the changer.
For example you could have something similar to
If GetSelectedTool =254 Then
.............. ETC
You would then only call tool 254 if you wish to change manually.
