Hello Guest it is November 13, 2026, 01:13:03 PM
Author Topic: Machine Cutting Oversize  (Read 12160 times)
« on: May 10, 2013, 03:54:28 AM »
My X3 is cutting 0.010" oversize, I have checked the kerrnell speed, done a MDI input X 1.00" and measured the movment it is spot on.
I am useing ArtCam Pro and has worked fine for years
Can anyone suggest what the problem may be?
Mike
Re: Machine Cutting Oversize
« Reply #1 on: May 10, 2013, 05:45:53 AM »
It can be due to a lot of things. It could  be how your defining the tool in ArtCam ...I don't know anything about ArtCam.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #2 on: May 10, 2013, 06:41:17 AM »
You don't say whether it's internally or externally oversize. A first guess might be (internal oversize) tool 0.005 oversize or (external oversize) tool 0.005 undersize. TBH my last guess would be kernel speed.
Ian
« Last Edit: May 10, 2013, 06:43:47 AM by stirling »
« Reply #3 on: May 10, 2013, 11:08:59 AM »
Rich
As I siad I have been useing ArtCam for years and nothing I do has changed, ArtCam has a tool menu like all Cam packages, you input the size be it inch or mm and it shows the size in decimil
Ian
The total is 1.00" as the part I am cutting is both sides, and new cutter, as I said the kernel speed is what it normaly is, that was the idea of the MDI test.
« Reply #4 on: May 10, 2013, 11:38:05 AM »
Ian
Typo, size should 0.010" must of been thinking about the MDI test
« Reply #5 on: June 02, 2013, 11:36:26 AM »
Problem solved, X axis slide gib stip was loose adjusted the screws so no slop in table and now cutting to size
Thanks for your help
Mike
