Hello
Guest
it is
October 14, 2026, 03:16:44 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Trouble with limit/home config
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Trouble with limit/home config (Read 22227 times)
k80user
19
Re: Trouble with limit/home config
Reply #10 on:
May 10, 2013, 12:58:51 PM »
One or the other, not sure which! What version do you recommend??
Carnoustie, Scotland
Reply #11 on:
May 10, 2013, 01:08:49 PM »
I use 056 and 057 on my machines but on the machines with the ESS and USB SS I am using older plugins and I think Jeff said you need 062 if you used the latest ESS/SS plugins.
k80user
19
Reply #12 on:
May 10, 2013, 01:19:51 PM »
One would think something as fundamental as referencing would be made to work in all releases. I am using 066...
Reply #13 on:
May 10, 2013, 01:45:31 PM »
You would think so.
Until you try with an earlier version we cant be sure that is your problem but I do know homing was an issue for me with one or other of these versions.
Please let us know if going to an earlier version solves your issues.
k80user
19
Reply #14 on:
May 11, 2013, 08:02:25 PM »
Version 062 works as expected. Guess I'll stick with that until I find something there that is broken and needed!
thanks for your help...
fyi...this is the second time I have posted this. The first version seems to have disappeared!
Reply #15 on:
May 12, 2013, 03:07:59 AM »
Thanks for coming back, glad you got it sorted. I will try
again
to make my feelings known regards 066 being the lockdown.
Print
Pages:
1
2
Go Up
« previous
next »
