Hello Guest it is November 13, 2026, 11:16:19 AM
Author Topic: help. config problem??  (Read 9762 times)
« on: May 06, 2013, 11:42:48 AM »
I have a system using mach 3 and for some unkrown reason it crashed the other day. defore this it was working perfectly. after that I had to reconfigure everything. now when i try to engrave text i get a serries of circles in the middle of the program. I use bobcad v.25 and until this crash all was well. when i run a simulation in bobcad all is well.it goes to hell in a handbasket in mach.any ideas on how to fix this would be greatly appreciated.-Andy
  •  9,377 9,377
Re: help. config problem??
« Reply #1 on: May 06, 2013, 11:54:38 AM »
Sounds like it could be 'crop circles' - In Config / General Config set the IJ Mode to the opposite of its current setting and see if that corrects the problem.
« Reply #2 on: May 06, 2013, 12:40:49 PM »
Thanks Tweakie. Perfect!!!-ANDY
« Reply #3 on: May 06, 2013, 01:48:32 PM »
Best to have the G91.1 or G90.1 in the first line of your code, that way it will always be correct no matter what is in general config.
