Hello Guest it is November 01, 2026, 10:12:40 AM
Author Topic: Any other HPGL to G-code converter ?  (Read 14856 times)
audio
« on: February 13, 2007, 07:43:36 AM »
Hello,
As an alternative to LAZYCAM which are the software names that can properly convert HPGL files (or DXF but first HPGL) into G-CODE? Thank you.  ;)
Re: Any other HPGL to G-code converter ?
« Reply #1 on: February 13, 2007, 10:03:49 PM »
Not that is free... What is the problem?
www.newfangledsolutions.com
www.machsupport.com
audio
« Reply #2 on: February 14, 2007, 12:24:48 PM »
Hello Brian,
Hello,
Here is my problem : the size of my drawing is not the size of the result in mach3.
I make some drawings in HPGL. They are well imported in Lazycam.
Suppose I import a circle which dia. is 43mm.
Then, Layer/object properties,
I have the hereunder numbers :
- extents        X   min : 0.0000   max : 1702.0000
                    Y   min : 0.0000   max : 1702.0000
- selectchain    X extents > same as above
- stock size      stock depth    : 0.0000
                     stock X length : 3651.0000
                     stock Y length : 3091.0000
Could you please advise what are the hereabove X and Y numbers for these 3 sections?
Thank you very much in advance.
