Hello Guest it is November 01, 2026, 10:12:38 AM
Author Topic: HPGL to G-code conversion with lazycam  (Read 10864 times)
audio
« on: February 13, 2007, 05:09:08 AM »
Hello,
Here is my problem : the size of my drawing is not the size of the result in mach3. ???
I make some drawings in HPGL. They are well imported in Lazycam.
Suppose I import a circle which dia. is 43mm.
Then, Layer/object properties,
I have the hereunder numbers :
- extents        X   min : 0.0000   max : 1702.0000
                    Y   min : 0.0000   max : 1702.0000
- selectchain    X extents > same as above
- stock size      stock depth    : 0.0000
                     stock X length : 3651.0000
                     stock Y length : 3091.0000
Could someone please advise what are the hereabove X and Y numbers for these 3 sections?
i have checked : this is not a mm/inch problem.
Thank you very much in advance. ;)
Re: HPGL to G-code conversion with lazycam
« Reply #1 on: February 24, 2007, 05:08:03 PM »
I would rescale the drawing and I think if you get the newest Rev of Mach3 with Lcam you will get the right size when you inport the drawing
thanks
Brian
www.newfangledsolutions.com
www.machsupport.com
