Hello Guest it is November 11, 2026, 08:54:44 PM
Author Topic: Y axis moving in the wrong direction  (Read 12365 times)
« on: April 25, 2013, 09:31:35 PM »
I am using VcarvePro, Mach3 with CRP4896 profile and Gercko G540.
I set sll azis to 0 in the lower left corner then enter G0X1Y1 on the MDI screen.  X moves in the correct diretion.  Y slams the bumper.  I have the same problem with g-code - the Y moves in the wrong direction.
I have searched the Mach3 help and cannot find any way to reverse the default direction of the Y axis.  Is there a way to handle this in Mach3?
Re: Y axis moving in the wrong direction
« Reply #1 on: April 25, 2013, 11:48:56 PM »
Go to ports & pins.  Click on motor outputs tab. Check or uncheck the DirLowActive to whatever it isn't now for that particular axis.
« Reply #2 on: April 26, 2013, 12:44:49 AM »
Thanks very much.
