Hello Guest it is November 22, 2026, 05:20:52 PM
Author Topic: tigger laser kind in dot pen making  (Read 7792 times)
« on: April 22, 2013, 05:40:14 PM »
Hi I'm putting together a machine of engraving, using a pneumatic hammer, and so far is always on from start to ending the program, it makes you consume more air and make more noise than necessary.
Is that the laser is triggered when you have to record, so I thought to use this method to open or close a solenoid valve, so that the marker start when you begin to make a point, line, etc., as configure the mach to have that function ?
