Hello Guest it is November 10, 2026, 01:53:17 AM
Author Topic: Using laser pointer to set x/y origin  (Read 14004 times)
« on: April 19, 2013, 10:11:17 AM »
I am sure that this has been covered (probably many times) in the forum, but I can't locate what I need.
I want to use a laser pointer bolted to the carriage to set the x-y origin.
So the steps would be
Manually position the laser dot to the desired point on the part with the jog controls.
Add a button to do the following:
Move the carriage some predetermined amount (distance between the laser dot and the cutter center).
Zero the x and y dro.
I am sure that this is trivial, but I don't have very much expertise in VB.
Re: Using laser pointer to set x/y origin
« Reply #1 on: April 19, 2013, 01:06:27 PM »
« Reply #2 on: April 19, 2013, 09:14:56 PM »
Or do this, which sets the zero position, but doesn't actually move it to zero. Just use the appropriate X and Y offsets.
XOffset = 3.43   'X offset from laser crosshair to spindle
YOffset = 4.322   'Y offset from laser crosshair to spindle
SetOEMDRO(800,XOffset)
SetOEMDRO(801,YOffset)
Sleep(125)
