Hello
Guest
it is
September 05, 2026, 11:19:05 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Parallel port break out board & isolators ?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Parallel port break out board & isolators ? (Read 11466 times)
Borisw37
11
on:
April 18, 2013, 02:55:05 PM »
I'm looking for a parallel port break out board to be used with Mach 3 and the Slo-Syn ss2000 motor controllers.
The SS2000 requires 5V control signals for STEP and DIR lines.
http://www.sal.wisc.edu/PFIS/docs/rss-vis/archive/public/Product%20Manuals/slo-syn/ss2000-md4.pdf
Suggestions?
Chaoticone
5,624
Precision Chaos
Re: Parallel port break out board & isolators ?
Reply #1 on:
April 18, 2013, 03:28:57 PM »
Really not enough info. here to make a good guess but the PMDX 122 works well for me.
If you could see the things I have in my head, you would be laughing too.
Borisw37
11
Reply #2 on:
April 18, 2013, 03:43:51 PM »
Which additional info should I provide?
Here are the specs from the SS2000 datasheet on the input signals
4.7.3 Level Requirements
OPTO
Voltage ....................4.5 to 6.0 VDC
Current.....................16 mA per signal used
Other Signals
Voltage
Low................... <=0.8 VDC
>=0.0 VDC
High.................. <=OPTO
>=OPTO - 1 volt
Current
Low................... <=16 mA
High.................. <=0.2 mA
Chaoticone
5,624
Precision Chaos
Reply #3 on:
April 18, 2013, 04:01:28 PM »
Thats good for the drives but what other OI will the machine have? Do you plan of controlling spindle speed with Mach? If so, what does it need to be? Digital IO, analog, PWM, etc.
Borisw37
11
Reply #4 on:
April 18, 2013, 04:03:33 PM »
Nope, no spindle speed. Mechanical or optical limit switches - maybe, but I can wire those in myself. The primary function now is just to control the PULSE and DIR for 3 of those SS2000 controllers, thus 3 axis.
Chaoticone
5,624
Precision Chaos
Reply #5 on:
April 18, 2013, 04:11:57 PM »
I think you would be fine with the PMDX 122 but you will have to decide for sure. They are good little boards.
Print
Pages:
1
Go Up
« previous
next »
