Hello Guest it is November 07, 2026, 11:04:37 AM
Author Topic: Hall of shame  (Read 1304822 times)
Re: Hall of shame
« Reply #120 on: October 24, 2020, 12:14:14 AM »
Hi Roger,
Because I can get a pirate copy for free from China?
Thats a pretty good reason that all development ceased in Mach3, I mean why would anyone bother continued development
and investment if users just pirate it?
Offline rcaffin
  •  1,073 1,073
Re: Hall of shame
« Reply #121 on: October 24, 2020, 01:58:33 AM »
Hi Craig
Oh, I don't think China was the reason for the move to Mach4, not at all.
Mach3 has a (small?) number of unrepairable bugs in it. They have been squeezed to one side, but they can not be fixed. Some of them at least are in the basic design, rather than being just programming errors. Mach3 started off simple, but complexities were added along the way, violating some of Art's assumptions. A fresh start was needed, with a clean sheet design, using the understanding but not the code from Mach3.
In addition, when Mach3 was first written, the LPT port was the only way to interface to the external hardware. Yes, I think one could add a second LPT port, but the whole design was constrained by the slow speed of the processors available then. Art F did a miracle job in creating a real-time system which could over-ride Windows XP (he hacked the ring system), but the OS moved on as well. In fact, I don't think the old Mach3 LPT port driver can run under anything other than XP. Later versions of Windows have a deliberate installation check to prevent loading what Art did. There were screams, which MS ignored.
If you take out the LPT driver and use an ESS (say), then the system can work (I believe) up to W10 - but I think only in 32-bit mode. The whole transition to 64-bit machines has orphaned a lot of gear in fact, expensive gear which I still have but can no longer use. Damn it!
Anyhow, if you are going to skip the use of the LPT, then it makes sense to rewrite parts of the core to skip that driver completely. The result is that while Mach3 can only update at 10 Hz, Mach4 can go quite a bit faster (40 Hz?), and can offload some very high speed stuff to an external pulse engine as well.
As to your basic question: it would not be a lot of trouble to change the security code in Mach3 to invalidate the Chinese pirates. Of course, they would probably just buy one new license and clone that across ebay, so why bother?
Mach3 continues to work fine (within its limits), and hundreds (thousands?) of users find it quite adequate for their needs. Sure, it has some bugs, but so does every version of Windows!
Roger
Re: Hall of shame
« Reply #122 on: April 19, 2023, 04:24:36 AM »
Patrick Hood Daniel
https://buildyourcnc.com/
Check the name of the license holder in the title bar.
https://youtu.be/ky8HDObEIGc?t=229
  •  9,375 9,375
Re: Hall of shame
« Reply #123 on: June 27, 2024, 11:02:45 AM »
As the Chinese businesses quite often change their trading names on a regular basis here is another to add to the list of Pirate License providers.
  •  9,375 9,375
Re: Hall of shame
« Reply #124 on: June 27, 2024, 11:14:02 PM »
The Chinese business 'Blue Elephant' also provide a cracked version of Mach3 and a Pirate License with their machines.
I can't contact Mach about a License I paid for and not received
« Reply #125 on: August 03, 2024, 08:56:55 PM »
I can't contact Mach about a License I paid for and not received. Their contact phone number is no longer active. Support does not reply to any of the 8 emails I sent. Does any know what's going on and tell me how I can contact Support?
Ray@Allaces.com
  •  9,375 9,375
Re: Hall of shame
« Reply #126 on: August 04, 2024, 12:32:40 AM »
Ray@Allaces.com
Check your Junk / Spam email folder as sometimes the license file that has been sent and email replys may end up there.
Re: Hall of shame
« Reply #127 on: August 04, 2024, 01:39:01 AM »
Tweakie,
I did check my spam folder each time. Do you have a way for me to contact support directly? I tried the phone number on the website that no longer works and filled out various forms with no reply. Are you able to contact them? If so please provide that contact number or email. Thanks for your response.,.. Ray LeBel
« Last Edit: August 04, 2024, 01:40:47 AM by allaces »
  •  9,375 9,375
Re: Hall of shame
« Reply #128 on: August 04, 2024, 04:40:09 AM »
Hi Ray,
Unfortunately telephone support for Mach3/4 product ended some time back so the only way to get any information is to use the NFS email support service... https://www.machsupport.com/contact-us/
It may currently be vacation season so it could take a while to get a reply so be patient.
  •  9,375 9,375
Re: Hall of shame
« Reply #129 on: May 24, 2025, 02:42:43 AM »
Changzhou continue to launch new products whilst still demonstrating their total disregard for the Artsoft licensing terms and conditions.
