Hello Guest it is October 04, 2026, 07:46:21 AM
Author Topic: ı add button puggin video but dont dont dont work pls help ???  (Read 49118 times)
Plugin Control >Video Window> How ı can open button ???
 ı can add Button mach3 first page button names "Camera"
ı want when ı click this button Plugin Control >Video Window Open screen
I watched the roads;
1-)   SendKeys ("+%PV")     ; ı cant work What's wrong with - ı open first page and click camera button but nothing at all happens
2-)  DoMenu( 6,1 )              ; ı cant work What's wrong with - ı open first page and click camera button but nothing at all happens
how ı can please help ?
  •  9,374 9,374
Re: ı add button puggin video but dont dont dont work pls help ???
« Reply #1 on: April 15, 2013, 03:25:37 AM »
Should it not be   SendKeys "%PV"
« Reply #2 on: April 15, 2013, 04:35:59 PM »
ı try that but no change :/   SendKeys "%PV"
ı click button but no change screen :((
« Reply #3 on: April 15, 2013, 06:46:40 PM »
SendKeys Command is not work please help me  ??? ??? ??? ??? :-X
  •  9,374 9,374
« Reply #4 on: April 16, 2013, 01:04:13 AM »
Have you enabled Brian’s plugin ( Config / Config Plugins) ?
You may find this thread of interest http://www.machsupport.com/forum/index.php/topic,22932.0.html
Also you may wish to try Klaus’s video window, which seems to work better for me – the details are here http://www.kd-dietz.com/klausphp/pages/ger/plugins/webcam/description/wcam_description.html
« Reply #5 on: April 16, 2013, 05:14:12 AM »
video manually running smoothly. I would like to use mach3 video window mode.
What if I did not work in mach3 sendkeys command.
  for example: SendKeys "J", the result is not working ..
  for example: SendKeys "a" results not work ..
I can not get no response when I press the button I added.
Could it be for using windows7?
Seems so simple, but the fact that I worked day and night to one week I could not: (
  •  9,374 9,374
« Reply #6 on: April 16, 2013, 05:59:47 AM »
You may be right and the problem could be related to using Win7.
So you can open Brian's video window manually.
Will the video window display the picture from your camera ?
« Reply #7 on: April 16, 2013, 07:05:00 AM »
When I click on any area of ​​the camera coordinates in the machine that I want to go to  :-\
will it work suggested that scrpt - http://www.machsupport.com/forum/index.php/topic,22932.0.html
Do you have windows 7 using the SendKeys command?
  •  9,374 9,374
« Reply #8 on: April 16, 2013, 07:11:54 AM »
No - I use WinXP.
« Reply #9 on: April 16, 2013, 10:18:21 AM »
I can't speak about the "Video Window" plugin. My camera plugin can switch the camera window on / off with a SetLed command, which can be assigned to a button.
Klaus
The brain isn't a soap, it doesn't shrink when used.
