Hello
Guest
it is
November 11, 2026, 05:41:55 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
SmoothStepper USB
(Moderator:
Warp9TD
clientwakeup board!?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: clientwakeup board!? (Read 12791 times)
cam4ge
20
on:
April 11, 2013, 03:26:48 PM »
i keep getting the error clientwakeup board not responding. how do i fix this problem?
Jeff_Birt
1,107
Re: clientwakeup board!?
Reply #1 on:
April 12, 2013, 01:06:38 PM »
That message is telling you the plug-in can't talk to the ESS. Most likely causes are that you don't have your PCs network adapter configured properly or your firewall is blocking the communication.
Happy machining , Jeff Birt
Check out
www.soigeneris.com
Jeff_Birt
1,107
Reply #2 on:
April 12, 2013, 03:41:16 PM »
I just got your voicemail from yesterday. Does your PC have an internet connection as well? If so I can remote in so we can both see the screen. It is typically much easier to find the issue if we can talk and both see the screen at the same time.
Check out
www.soigeneris.com
cam4ge
20
Reply #3 on:
April 14, 2013, 12:41:55 AM »
thank you Jeff .i do have internet at my shop. i have now gotten past that one. the only thing i need now is to configure a pmdx126 board for an ethernet smooth stepper. i am having trouble configuring using my methods.aka trial and error.
Print
Pages:
1
Go Up
« previous
next »
