Hello Guest it is October 21, 2026, 04:05:24 AM
Author Topic: Mach 3 motor tuning  (Read 33317 times)
Re: Mach 3 motor tuning
« Reply #20 on: April 19, 2013, 07:45:45 AM »
sorry for the late follow up. Here is the xml file. Interestingly enough is that if you use continuous jog, it jogs slow no matter how you change the feed but if you are in step mode it moves relative to the feed setting so i can make it move much faster.
« Reply #21 on: April 19, 2013, 07:57:39 AM »
Again it is working fine here, does it jog slowly if you use your mouse to click the buttons on the fly out screen?
If so then possibly a keyboard issue.
« Reply #22 on: April 19, 2013, 07:59:12 AM »
that is mainly what we do when joggin
« Reply #23 on: April 19, 2013, 08:00:21 AM »
Well afraid I have no idea where your problem is as the xml seems to work fine here.
« Reply #24 on: April 19, 2013, 08:20:41 AM »
bummer. Thanks for your help though.
