Hello Guest it is November 13, 2026, 09:47:21 AM
Author Topic: Mach is fine fo 3 axis but fails when 4th axis is configured  (Read 10982 times)
« on: April 10, 2013, 06:39:38 PM »
I have recently added a 4th axis to my cnc mill and have the following problem.
3 axis XYZ work fine without the 4th axis enabled in mach - config - ports and pins.
enable 4th axis in mach - config - ports and pins all axis fail.
deselect 4th axis  in mach - config - ports and pins all axis still fail.
restart mach 3 axis work fine.
Pins set as follows:
Axis       Dir       Step
x            2          3
y            4          5
z            6          7
a            8          9
I am using a MRI-PCIPP2 pci  and I suspect it is something to do wit the Mode. It is supposed to be SPP/EPP/ECP compatable  and auto selected.
OS is XP and up to date on Updates.
What I think is the problem is the PCI card is in the incorrect mode, but I have been unable to find any info on manually changing it.
Any help
Re: Mach is fine fo 3 axis but fails when 4th axis is configured
« Reply #1 on: April 15, 2013, 05:08:33 PM »
Can you attach your xml and I will see if there is an issue in it.
« Reply #2 on: January 11, 2016, 04:32:09 PM »
Folks,
 I'm new the the CNC stuff - I purchased a G704 and a CNC controls for 4 axis - gotta have the rotary for engraving and light prototyping. I think I have the X/Y/Z tuned but I'm having trouble with the A axis "rotary" does anyone know where I could get some help in making sure my machine and Mach 3 is configured properly  - I'll pay to play
Offline Vogavt
  •  260 260
« Reply #3 on: January 20, 2016, 01:08:36 PM »
Did you get it sorted out?
