Hello Guest it is September 05, 2026, 08:55:04 PM
Author Topic: Text wizard/engraving issues  (Read 24068 times)
« on: April 08, 2013, 11:25:15 PM »
I'm running into a very perplexing (for me) issue when running the code generated by the text engraving wizard on mach3.
I've tried both Helvetica and IsoCp and both seem to have problems for me. If I recall correctly, Helvectica is the selected font for "TEST TEST". "Trust" was done with IsoCp, but note that the "S" characters are wildly misshapen in both. Also, the vertical portion of the "T" is not centered on the horizontal portion. The "O" character is also quite misshapen (it's square rather than round or oval), along with the middle "half" lines on E's and F's smushed into the top or bottom line on smaller characters.
I've tried character heights of .0625" (not shown), .125 ("TRUST"), and .500 ("TEST"). Spacing is 100%, DOC is .005", I'm using a .010" single-flute carbide cutter at 4500rpm. I'm doing test cuts on 3003 AL stock. The "TEST TEST" engravings are rough due to having been done too fast (8IPM). I'm now going at 2IPM ("TRUST").
This is on a converted HF mini-mill (X2-size) utilizing a G540, 380oz stepper motors, 48v power supply, and a CNCFusion kit (incl. re-packed ball nuts and screws). There's a total of about 30-mins run time on the machine (it was converted before ever being powered up). 25,000hz, and the driver tests always come up excellent (sits at 25,000hz occasionally "blipping" to 24,999 or 25,001hz).
Up to this point I've only done simple "linear" sorts of jobs where I was widening a slot by .030" or other such "simple" operations however I'd like to be able to start using the machine more completely.
I re-trammed the X axis today (it's about .007" off at the moment. I'm going to redo it after doing the "bolt" mod to make the adjustments more precise and easily obtainable). I haven't come up with a good way to tram the Y yet. Even still, that doesn't explain the square O's and such.
Where should I start to look to resolve this issue? Slow down the acceleration and max speed on the motors? Does this seem like an issue with dropped/skipped pulses, or do I need to look elsewhere?
I've been fussing with this on and off for a couple weeks and I'm sending up the white flag.
Thanks in advance!
« Last Edit: April 08, 2013, 11:32:58 PM by sillycon »
Re: Text wizard/engraving issues
« Reply #1 on: April 09, 2013, 12:57:33 AM »
Do you have backlash compensation turned on or off?  If on, is it accurately set to the actual value for your screws?  You could try an alternative engraving package to see if that gives the same problem - F-Engrave is free, and I have used it successfully to engrave text.  It has the nice feature that it deals with multiple lines.  It generates g-code that you can then import into Mach to run, this will check if the problem is in the Mach wizard or your setup.
« Reply #2 on: April 09, 2013, 10:24:21 AM »
I never entered into the backlash compensation window that I can recall, so it's likely whatever the default for Mach3 would be (I would assume "off", so perhaps my assumption that it's "off" is my problem right there?).
I'll give F-engrave a shot as well to sanity check. Thanks for the suggestion.
Though, frankly, I have to think that the issue is in my setup because I can't imagine something like this sliding for so long past 10k+ users.
« Reply #3 on: April 09, 2013, 12:27:16 PM »
Does the engrave text display correctly in the toolpath display ?
« Reply #4 on: April 09, 2013, 12:29:27 PM »
Yes, display text appears to be very nice, smooth, and symmetrical (yet another reason I expect the problem is in an unknown place in my setup).
« Reply #5 on: April 09, 2013, 12:40:14 PM »
Then the problem is in your machine, Probably in motor tuning setting too aggressive and you are loosing steps.
« Reply #6 on: April 09, 2013, 02:23:59 PM »
Alright, thanks for confirming my suspicion. I'll go back to square one on the motor tuning and see where that takes me.
« Reply #7 on: April 10, 2013, 03:36:13 AM »
It might just be worth checking that backlash compensation is indeed turned off....and could your problem be caused by uncorrected backlash in the screws?
« Reply #8 on: April 10, 2013, 10:09:20 AM »
I'll also verify that the backlash compensation is off, thanks; and I'll double check the backlash on the machine as well.
Offline rcaffin
  •  1,073 1,073
« Reply #9 on: April 14, 2013, 05:44:06 AM »
Looks like a purely mechanical engineering problem to me. Backlash on the Y axis maybe.
