Hello Guest it is November 07, 2026, 02:06:12 AM
Author Topic: Metric units In drill cycle not metric in Z  (Read 42660 times)
« on: April 06, 2013, 04:19:32 PM »
Hi Ron,
while playing around with the wizard demo I found this.
The Z depth of both the circular pocket and the hole circle is the same in the settings.
X and Y is OK but Z seems to be inches in all drill operations. (screenshot)
BTW I really like the clean easy to use design.
Regards
Alex
Re: Metric units In drill cycle not metric in Z
« Reply #1 on: April 06, 2013, 08:15:53 PM »
That is a bug in the toolpath display, the gcode will be correct. The toolpath is the same code as used in the mach4 product, and it will get fixed before Mach4 is released.
