Hello Guest it is November 13, 2026, 09:43:26 AM
Author Topic: DRO's keyboard entry gone  (Read 10593 times)
« on: April 03, 2013, 04:11:06 PM »
All of a sudden I can't enter numbers from the keyboard into the Axis DRO's.  Only a mouse-user keyboard pane/pain.  How do I get that functionality back and what did I do to lose it?
Much thanks,
MikeF2
Re: DRO's keyboard entry gone
« Reply #1 on: April 03, 2013, 04:38:04 PM »
Have you recently upgraded to Ver 066 or 067? I have had that issue in Turn with these versions.
The other thing it could be is you are viewing machine coords, if that is the case then the numbers will be getting entered just you wont see them as you are not viewing work coords.
« Reply #2 on: April 03, 2013, 04:56:48 PM »
Up top, under OPERATOR, is Auto Calculator checked ?
If so, un-check it.
Russ
« Reply #3 on: April 03, 2013, 05:00:43 PM »
ah ok, I see now what you are saying, lucky Russ is on the ball ;D
« Reply #4 on: April 03, 2013, 05:06:20 PM »
Hurray!  Yes, that (auto-calculator toggle) did it.  Makes me wish I would have registered a couple months ago.  Thanks a lot Russ.
