Hello Guest it is September 28, 2026, 03:54:23 AM
Author Topic: reference X and Y axis then move X and Y to center of table  (Read 10189 times)
Offline EL34
  •  10 10
« on: March 29, 2013, 10:00:13 AM »
My 3D printer has an 8 x 8 inch bed
Before each printing session I reference the X and Y axis and then jog to the center of the bed at X4 and Y4 then zero out the X and Y axis dro's
I would like to add a button that does all this automatically but I am not sure how to use Function refX and function refY in a VB script
The basics of the operation would be
refX
set X dro to zero
refY
set Y dro to zero
G0 X4 Y4
set X and Y dro to zero
Thanks for any help on this
Re: reference X and Y axis then move X and Y to center of table
« Reply #1 on: March 29, 2013, 11:04:02 AM »
Give this a whirl, there are MANY ways to do this .This is just a replication of how you described the motion.
Dobutton(22)   'RefX
While Ismoving()
Wend
SetDro(0,0)
DoButton(23)   'RefY
While Ismoving()
Wend
SetDro(1,0)
Code"G0 X4 Y4"   'move to new location
While Ismoving()
Wend
SetDro(0,0)
SetDro(1,0)
END
Offline EL34
  •  10 10
« Reply #2 on: March 29, 2013, 11:55:23 AM »
Excellent, it works perfectly
thank you so much!
Offline EL34
  •  10 10
« Reply #3 on: March 29, 2013, 12:03:59 PM »
I spoke too soon
It worked fine before I had loaded some metric G code
I work mostly in inches on Mach3
After running your code I loaded some G-code that was metric and instead of moving X and Y 4 inches it moved 4 millimeters
Not sure how I can do this with imperial and metric
Is there a way to figure this out before the machine proceeds with the first lines of code?
« Reply #4 on: March 29, 2013, 12:11:03 PM »
Dobutton(22)   'RefX
While Ismoving()
Wend
SetDro(0,0)
DoButton(23)   'RefY
While Ismoving()
Wend
SetDro(1,0)
While Ismoving()
Wend
SetDro(0,0)
SetDro(1,0)
END
Just add this to TP's cool solution
Code "G20"
Dobutton(22)   'RefX
While Ismoving()
Wend
SetDro(0,0)
DoButton(23)   'RefY
While Ismoving()
Wend
SetDro(1,0)
While Ismoving()
Wend
SetDro(0,0)
SetDro(1,0)
END
Offline EL34
  •  10 10
« Reply #5 on: March 29, 2013, 12:16:00 PM »
Thanks, that did the trick
I loaded some metric Gcode and it worked perfectly
This saves me several steps having one button that does it all
I appreciate the help guys
