Hello Guest it is November 13, 2026, 05:00:02 PM
Author Topic: Mach3 and pokeys Trouble  (Read 12043 times)
Offline 1hxo
  •  20 20
« on: March 28, 2013, 08:05:21 AM »
Hi
I have  problems with pokeys and mach3
When I connect Pokeys56U to my home pc(win 7 64bit) i can use my axes with the
Handcontrol.After i setup the right motortunning.
When i connect pokeys56U to my cnc Laptop(asus f3jm win xp 32bit) i can´t use my axes because the motors stutter like i was setup the motortunning wrong.
Why do the laptop such strange things?And can i do something again this?
And the other thing is when i make a circle the machine goes stutter to the position then when they make the circle they drive normal.
It looks then when i use the handcontrol and set the jogmode to step 0,001 and then i push the move button permanently.It´s stutters
for me it looks that they become the step and dir signal to slowly
Can i set the signal speed somewhere?
And when i make a homing mach3 dont zero my homing
When i click the ref all Home on They do nothing i must click Zero X then he drives my zero axes to home and dont zero.the same with Y
The button ref all home doesnt work i must click Zero X and Zero Y
I have several settings in mach3 behind me maybe i have overlook something
My machine:
Pokyes56U
Stepdriver are tb6560AHQ from Here:
http://rc-letmathe.de/product_info.php?cPath=61_159&products_id=1351
all limit and home switches are installed and they function
Mach 3 Version R3.043.067
Offline 1hxo
  •  20 20
Re: Mach3 and pokeys Trouble
« Reply #1 on: April 08, 2013, 02:30:04 PM »
Ok allmost all problems solved.
