Hello Guest it is November 01, 2026, 10:12:53 AM
Author Topic: lazy cam and auto cad  (Read 11396 times)
« on: February 08, 2007, 01:08:13 PM »
i am using auto cad 14. i downloaded a program to convert my dwg file to a dxf file. when i try to import the dxf file into lazy cam i get a message that says "No entities found in import"  what am i doing wrong
Thank You for the help
Re: lazy cam and auto cad
« Reply #1 on: February 08, 2007, 01:58:20 PM »
I don't know autocad 14, but you should be able to "export" or "save as" the file directlly from autocad. This could prevent some troubles done by the dwg to dxf converter.
I tested autocad 2007, save all as dwg (using format autocad 2000) - it is a option when saving as dwg, without problems.
Filipe
« Reply #2 on: February 08, 2007, 02:18:06 PM »
yes i am sorry i am saving it directly from auto cad as a dxf file and still getting the same error message when i try to open the file in lazy cam
« Reply #3 on: February 09, 2007, 04:29:03 AM »
Post the file were, I can have a look at it, and try to help.
« Reply #4 on: February 12, 2007, 02:11:25 PM »
See if you can export it as an autocad rev 12DXF ... I don't know autocad.. never used the stuff.
www.newfangledsolutions.com
www.machsupport.com
