Hello Guest it is October 20, 2026, 08:39:46 PM
Author Topic: Visual Studio 2010 or newer  (Read 14351 times)
« on: March 26, 2013, 03:17:07 PM »
Does anyone here have a  full version of Visual Studio 2010 or newer and would be willing to compile a program for me ?
Re: Visual Studio 2010 or newer
« Reply #1 on: March 26, 2013, 06:33:57 PM »
And it cannot be "Express" - MUST be the full version....
« Reply #2 on: March 27, 2013, 12:19:30 PM »
Terry,
May I ask why a full version is required?
John Champlain
« Reply #3 on: March 27, 2013, 12:34:29 PM »
HIYA John as I understand it with the express version you cannot compile the code with a command line variable where a file can be called with the function call as a command line call.
Shell "C:\Mach3\FUNCTION.exe Filename.txt" That way when the program is called it loads the file to use.
« Reply #4 on: March 27, 2013, 03:50:12 PM »
Terry,
Never tried that with Express versions.
I have long used VB.net express versions, but compile with a separate program.  I use Inno (http://www.jrsoftware.org/isdl.php), which is a free compiler, to generate my install files.  I was just curious if it might work for your purposes.
John Champlain
« Reply #5 on: March 27, 2013, 09:34:38 PM »
Looks like a functional addition, I like what I played with so far.
« Reply #6 on: March 27, 2013, 10:48:50 PM »
AH but yall don't have the simulator installed ? I do not see the icon for it in the tool tray.
