Hello Guest it is November 13, 2026, 05:00:27 PM
Author Topic: Help! Problems with installation of Pokeys plugin.  (Read 12870 times)
Offline Bloy
  •  158 158
« on: March 26, 2013, 06:20:52 AM »
I'm trying to install Pokeys onto a Vista PC running Mach3
The pictures show connection with the software, but in the plugin configuration, Mach isn't recognizing the Pokeys56U device.
I'd bet that I am just missing something simple, as I have never worked with pokeys before.
Could it be that I have the Mach3 folder in "C" named other than "Mach3"?  I've renamed it back to "Mach3" but maybe it is too late and Mach has to be reinstalled?
At this time I don't have a clue.  I've messed with different plugins ....now it is clear as mud.
John
« Last Edit: March 26, 2013, 06:36:43 AM by Bloy »
Offline Bloy
  •  158 158
Re: Help! Problems with installation of Pokeys plugin.
« Reply #1 on: March 26, 2013, 09:04:07 AM »
Okay, it WAS simple.... not having modio/modbus enabled in Mach3.....
Moving on...
Offline Bloy
  •  158 158
« Reply #2 on: March 26, 2013, 09:40:01 AM »
Moving on...
Although I'm still in a fog here, it is working.     After disabling the modio/modbus to check what happens, the plugin still works.
So I'm just going to keep plodding along and work through the next snag.  ::)
