Hello Guest it is November 23, 2026, 02:20:03 AM
Author Topic: need to retrieve deleted session profile  (Read 10244 times)
« on: March 22, 2013, 06:00:36 PM »
I opened the "mach 3 loader" and accidentally deleted my machine profile from the current profile dialog box. How do I retrieve it?
Re: need to retrieve deleted session profile
« Reply #1 on: March 23, 2013, 02:47:05 AM »
You should find a backup folder, find the most recent with the name of your profile then copy and paste to your desktop. Then right click and rename and change the file extension from xbk to xml then finally paste it into the main Mach3 folder.
« Reply #2 on: March 25, 2013, 10:10:15 AM »
Thanks. I kept searching in the backup files and found a notepad document that explained the same thing that you suggested and it worked out. Thanks for your reply.
