Hello Guest it is October 17, 2026, 10:51:18 AM
Author Topic: Angular moves - choose direction?  (Read 23472 times)
Re: Angular moves - choose direction?
« Reply #10 on: March 22, 2013, 06:23:36 PM »
Very nice ! Hope you don't get into trouble on my account.
Hmmm. I don't see where that could swing 300 deg. though.
What degree pos. is it at in the pic ?
Russ
« Reply #11 on: March 22, 2013, 06:44:51 PM »
I think yall will find SOME of those options are broken.
Darn that list of things broken is getting longer and longer(;-)
You need to test every option you try, twice (;-) TP
« Reply #12 on: March 22, 2013, 06:50:42 PM »
Uh oh ..... wasn't aware of that.
There I go "assumin'" again.
Must proceed w/caution.
Will be interesting to see what actually works out here.
Russ
« Reply #13 on: March 23, 2013, 02:29:37 AM »
Always the way, anyways I will have a go at it and let you know the outcome in a few weeks once installed.
Thanks for the help so far, Jason.
edit: it is the rotate I am worried about more than the tilt. Tilt will only ever go 90 degrees downwards.
« Last Edit: March 23, 2013, 02:31:20 AM by garagecnc »
« Reply #14 on: March 23, 2013, 10:07:59 AM »
Sorry if I interfere,
maybe I am wrong, but I can't see a problem here.
I would do it like this. ( lets say we take the A axis )
calculate the steps per so that you get 1  Rotation of your spur Axis by 360 degrees.
UNCHECK "A axis is angular"  in Gen. Config UNCHECK rotational options.
Now a code like G0 ( or G1 ) A180 should turn your axis 180 degree in one direction
G0 A0 back to old position.
Now IF there is a problem with the rotational axis ( A , B , C ) ( no Probs here )
THEN you can use the  X or Y or Z axis for that, IF you have any as a spare.
Same setup ( steps per unit etc. like A,B,C )
just a thought
Alex
