Hello
Guest
it is
November 04, 2026, 03:23:16 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
General CNC Chat
Share Your GCode
Help with gcode...
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Help with gcode... (Read 59475 times)
shtk13
11
Help with gcode...
on:
March 21, 2013, 11:56:00 AM »
I am working on project for my son for school and i cannot get an output file in gcode...
everytime i try and turn it to gcode .ngc inkscape freezes up i don't know if it's because of how many objects
or if it's to complex i don't know but i only need it to be 100mm by 100mm just trying to engrave
the main issue is we have been trying to run this all week and weekend the the thing is due tomorrow afternoon
Thank you to anyone who can help by either turning it into gcode or explaining to me why it's not working properly
shtk13
11
Re: Help with gcode...
Reply #1 on:
March 21, 2013, 12:16:14 PM »
I'm running this art in inkscape and using that to xfer into .ncg and opening it up on the linus cnc axis program
Tweakie.CNC
9,375
Super Kitty
Reply #2 on:
March 21, 2013, 12:40:08 PM »
Probably need a better image than the one posted but I can get the outline engraving, minus the circles, easily enough if it's any help to you.
shtk13
11
Reply #3 on:
March 21, 2013, 12:46:54 PM »
I'll get a bigger image here but the txt code you sent will work in axis ? doesn't seem to be doing anything
shtk13
11
Reply #4 on:
March 21, 2013, 12:55:58 PM »
Here is a larger image
The format needed for the machine program is .ngc
if you need to email it's shtk13@gmail.com
Tweakie.CNC
9,375
Super Kitty
Reply #5 on:
March 21, 2013, 01:05:33 PM »
Sorry, but I don't think the .ngc file extension is a supported Mach3 format.
shtk13
11
Reply #6 on:
March 21, 2013, 01:24:07 PM »
NC is and i can convert that
BR549
6,965
Reply #7 on:
March 21, 2013, 03:34:45 PM »
Here it is in NGC and APPROX 4"X4"
shtk13
11
Reply #8 on:
March 21, 2013, 03:50:09 PM »
Thank you i'll check this out
shtk13
11
Reply #9 on:
March 21, 2013, 03:58:33 PM »
Not working i am using a different program to run the tests and the machine probably why it isn't working but when i try to get this switched to gcode through inkscape it keep freezing up because it's got to many things im guessing
Your code when put into the program won't read properly
Print
Pages:
1
2
Go Up
« previous
next »
