Hello Guest it is November 13, 2026, 08:00:09 PM
Author Topic: Parallel Port output pins ?  (Read 11556 times)
« on: March 20, 2013, 01:52:10 PM »
I'm in the process of making wiring up my 3axis CNC machine and trying to figure out which pins are suitable for output. I have found plenty of data online (http://www.lammertbies.nl/comm/cable/parallel.html) but not everything is matching up.
I need 6 outputs for the motors and another 4-5 for additional functions. Problem is that when connected to the PC, the following pins on the DB25 all ring out to GND (14,16-25). According to the info I found, pins 14,16,17 should be outputs.
Am I doing something wrong?
Re: Parallel Port output pins ?
« Reply #1 on: March 20, 2013, 02:11:56 PM »
The cable needs to be a straight thru cable.  I think most printer cables are not.  Second guees would be, possibly those pins have pull down resistors in the circuit some where.
« Reply #2 on: March 20, 2013, 02:19:52 PM »
Cable is straight through, I checked it pin-to-pin before connecting it to the PC. Its a parallel port printer so DB25 to 36pin, but the pin out matches one in the link above.
  •  9,377 9,377
« Reply #3 on: March 21, 2013, 05:03:20 AM »
Hi Boris,
I think you need the wiring diagram of the breakout board you are using to establish the correct connections.
Obviously there must be exceptions with a 36 pin Centronics connector but all the breakout boards I have ever used have a DB25 connector so the PC to Machine LPT cable is straight through connections DB25 to DB25.
