Hello Guest it is November 13, 2026, 08:08:42 PM
Author Topic: Z Value increases on its own - Problem  (Read 12762 times)
« on: March 20, 2013, 05:00:34 AM »
Hi All,
We have a problem where the Z Value (Only the DRO) suddenly moves up to the THC MAX Level - For no apparent reason...
We manufacture CNC Plasma Machines and the problem only happens now and then... We use same PC's and same software version (Version R3.043.022).
Example: Cutting a square plate 500mm x500mm
- Start to cut - no problem (THC is active)
- THC is working - manually adjust the height with our own THC module
- THC Up/DOWN lights flicker - communication is good with THC controller
- Suddenly the ZValue DRO (not the torch itself) will move up (and quick - within 1s) to Z50 (same as our THC max value) (no THC UP signal recieved...)
- Plate is deforming and torch tip comes closer to material
- Because MACH3 thinks it is already at the THC MAX value it does not move torch up and torch touches plate and Collision switch activates
 or
- if the cut is completed without crashing the torch half way, at the end of the cut the Torch crashes into the plate trying to move to [G00 Z30]... It thinks it's at 50mm above material...
Anybody have any idea about this?
CD
  •  9,377 9,377
Re: Z Value increases on its own - Problem
« Reply #1 on: March 20, 2013, 06:42:26 AM »
Hi CD,
I don’t have plasma or use THC so this response is not based on experience...
My best guess, or what I would look for, would be electrical noise pickup on, or associated with, the THC Up signal.
Perhaps check cable runs, shielding, grounding etc. and if necessary fit filters, ferrite's etc.
« Reply #2 on: March 20, 2013, 06:49:34 AM »
Thanks, I will try and respond if I cannot find a solution!
Appreciate!
CD
« Reply #3 on: March 20, 2013, 07:15:08 AM »
I experienced the same problem but only happened after I used the Feed Hold command then back to cycle start. The z axis slowly creeps back toward the home position. It seems to be a mach 3 problem. The problem occures on several gcode programs. As long as I don't use feed hold... I don't have the z creeping issue.
« Reply #4 on: March 20, 2013, 08:03:25 AM »
geh7552, What version of Mach is this creeping happening in?  I would be interested in seeing the code that is used when this happens as well.
« Reply #5 on: March 20, 2013, 08:11:01 AM »
Geh7552, what do you mean with "creeping"? Is that only the Z DRO or is it the actual head? With our machine it goes to the max value very quick! I will also see If I can get some G-Code where it happened!
CD
« Reply #6 on: March 20, 2013, 11:10:15 AM »
I used the feed hold then jogged the cutter back in the Y axis to clear chips. Then resumed cutting. I noticed the Z axis pulsing 0.001" back to Z home at 2 or 3 seconds intervals. The stepper motor was moving. I reloaded the program and continued without problems. Later I ran another program and used feed hold. After restarting again the Z axis (motor and DRO) was pulsing 0.001" towards the home position.
