Hello Guest it is September 05, 2026, 09:02:11 PM
Author Topic: Using Mach 3...  (Read 29923 times)
Re: Using Mach 3...
« Reply #10 on: March 25, 2013, 12:14:12 PM »
Dear Hood
Yes it is what I did...and , as I said before, all its ok...! But the busillis is that, I can't read degrees on the DRO while the axes runs! I can read values from 0 to 100 according the reduction ration !!! I read values 0° to 360° if I invert , by pendant, the rotation sense starting from the "0 home" position .
Best regards
Re: Using Mach 3...
« Reply #11 on: March 25, 2013, 01:11:41 PM »
Sorry I do not understand what you are meaning.
Re: Using Mach 3...
« Reply #12 on: March 25, 2013, 01:14:26 PM »
dear Hood..
premise that...all works....just an indication problem on the DRO....
when the axe run using the pendant....what You are expecting to read on the A DRO?
Re: Using Mach 3...
« Reply #13 on: March 25, 2013, 01:15:51 PM »
I do not really understand what you are meaning by the axis running from the pendant.
Re: Using Mach 3...
« Reply #14 on: March 25, 2013, 01:20:06 PM »
Dear Hood
I have a jog control and when I like to use the Mill on manual I use it...! So if I use it, or the jog controls, pushing the buttons 4+ or 4- the axe move...! Ok?
Re: Using Mach 3...
« Reply #15 on: March 25, 2013, 01:28:09 PM »
If you press the tab key on your keyboard then use the 4+ and 4- buttons there can you jog fine?
I loaded your xml and I can jog the 4th axis fully from 0 to 360 and back again no issues.
Only thing I can think of is you have rotational softlimits enabled so that may be affecting things but why I have no idea as it doesnt affect things here.
Re: Using Mach 3...
« Reply #16 on: March 25, 2013, 01:39:19 PM »
Dear Hood
Yes it is Hood. Please  what you read on the DRO? I mean values from 0 to 360 or from 0 to 100...!
Re: Using Mach 3...
« Reply #17 on: March 25, 2013, 01:48:45 PM »
0-360 but I have the standard screenset loaded as you were using one I dont have so maybe try loading the standard screenset.
Re: Using Mach 3...
« Reply #18 on: March 25, 2013, 01:51:49 PM »
So I read from 0 to 100....! I can read 0 to 360 REVERSING the rotation sense...! I have the standard one plus the macro made by Hoss for zeroing the Z axes...!
Re: Using Mach 3...
« Reply #19 on: March 25, 2013, 03:57:50 PM »
I can go from 0-360 or 360-0 by jogging in your xml so either your screenset, a brain or macropump or similar that must be screwing it up for you.
