Hello Guest it is November 03, 2026, 08:46:43 AM
Author Topic: Drawing / engraving size difference  (Read 11530 times)
audio
« on: February 07, 2007, 07:26:32 AM »
hello  everybody. I am happy that such a website exists.
To sum up, I make a drawing (in mm - metric) and export it using HPGL.
I then use  the  Lazycam section  to import the  HPGL  file to generate a G-code. But
when engraving, the size of the result is totally different.
Is there a parameter I must change? I changed  the "scale drawing" in the
left LAZYCAM menue. The best result is with Xdimension « «6 » but  seems to  depends of the ratio X/Y. How can I be sure I engrave the same drawing I made? ( Same
dimensions)...
How  to  be sure mm's is  slected in the lazycam file auto-clean button options. ? What parameters should I change to modify that?
Is  there  a  manual  for  the lazycam ?
Note : I run under Mach3 R2.0.009, Lazycam 2.66
Thank you very much for your help in advance.
Best  regards.
Fred.
« Last Edit: February 07, 2007, 07:32:41 AM by audio »
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Drawing / engraving size difference
« Reply #1 on: February 07, 2007, 01:09:41 PM »
Hi fred,
can you export DXF from your drawing package.
I think HPGL is scaled to fit on your printer page, you may have an option to export in 1:1 scale this may cure your problem.
Graham.
« Last Edit: February 07, 2007, 04:55:03 PM by Graham Waterworth »
audio
« Reply #2 on: February 07, 2007, 02:51:19 PM »
Thank you very much Graham! ;)
I am now on  the road for 1 week. As soon  as I am back, I try this good idea.
But if someone else has another good idea...
« Last Edit: February 07, 2007, 02:54:53 PM by audio »
audio
« Reply #3 on: February 07, 2007, 03:04:39 PM »
One question : I  will not  have  this problem with a DXF file?
If so, I can just choose  a converter  to  tansform  my  HPGL or JPEG or  BPM files  into  DXF  ones?
Thanks  again for  your  precious  help.
Best.
Fred
« Last Edit: February 07, 2007, 03:18:28 PM by audio »
