Hello Guest it is November 13, 2026, 08:29:18 PM
Author Topic: XML, Z axis  (Read 6963 times)
Offline dude1
  •  1,253 1,253
XML, Z axis
« on: March 18, 2013, 04:55:24 PM »
could someone look over my XML see if they can find anything wrong in my config.
solved my z axis problem change all velocity's to be the same on x, y b and z it has made z go from being 2.5 mm out over 1500 z moves to 0.12 out.
also x, y-b are set at 25 steps per mm z is 75 steps per mm x and y-b are very accurate would change pulley size on z so its the same as x, y-b make it better???
any suggestion would be good
