Hello Guest it is September 23, 2026, 05:05:31 AM
Author Topic: E-Stop latching??  (Read 18343 times)
E-Stop latching??
« on: March 17, 2013, 08:02:00 PM »
I am trying to bring up a new CNC router and am using the PMDX-126 BOB, PMDX-134 motherboard w/G203V drivers, the USB SmoothStepper, and the PMDX-107 spindle controller.  Several E-stop switches are wired in series to the PMDX-134 and the function seems to work normally when Mach3 is not running (meaning the led on the BOB reflects the condition of any of the E-Stop switches), but when Mach3 is running, hitting E-stop causes Mach3 to shut everything down appropriately, but hitting the Reset button on the Mach3 screen doesn't clear the E-stop condition.  In fact, the led on the BOB stays lite regardless of whether or not you clear the switch (or hit the reset button on Mach3).  What is keeping it active??  Any suggestions would be much appreciated!
Re: E-Stop latching??
« Reply #1 on: March 18, 2013, 02:57:07 AM »
Attach your xml and I will see if I can find the issue.
Re: E-Stop latching?? - XML
« Reply #2 on: March 18, 2013, 03:00:08 PM »
Here you go.  Based on your comment, I ran the same setup with the pro forma Mach3Mill XML profile and estop appears not to latch, so it would appear that there is something in here causing the problem, but I can't seem to find it!
« Reply #3 on: March 18, 2013, 04:02:27 PM »
Seems to be working fine here with your xml, I hit the E-Stop and and Mach goes into reset, I release the E-Stop switch so its contacts are closed and I can then reset no problem.
What version of Mach are you using?, Can you disable the chargepump and see if that makes a difference.
« Reply #4 on: March 18, 2013, 04:15:54 PM »
Indeed!  I disabled the charge pump and the E-stop works as expected.  What gives??
I am running v 67...
« Reply #5 on: March 18, 2013, 04:27:35 PM »
Ok just tested with 067 and its nothing to do with that as its fine here.
It is likely either the G540 or the PMDX that is the problem with the way its handling the chargepump.
I never used the chargepump as its intended purpose is to stop motor movement during windows startup when using the parallel port. As the SS will not output any commands until Mach is started then there is no real need for the chargepump.
« Reply #6 on: March 18, 2013, 05:11:41 PM »
I was headed in that direction....just disable the charge pump.
thanks for your help!
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #7 on: March 19, 2013, 07:29:03 AM »
The G540 requires that the charge pump be on even during Estop. There is a setting in the general config page to select this behavior. Gecko provides a profile with everything already configured for the G540, it makes a good starting point so you don't get bit on the butt with problems like this.
Happy machining , Jeff Birt
« Reply #8 on: March 19, 2013, 09:48:27 AM »
He already had that set Jeff so must be something with the way the PMDX is handling things.
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #9 on: March 19, 2013, 10:05:08 AM »
Why use a BOB with a G540? The G540 has a BOB built in! Sounds like over complicating the situation to me :)
