Hello Guest it is November 13, 2026, 07:32:28 PM
Author Topic: Different Use of Anti-Dive Function  (Read 6889 times)
« on: March 15, 2013, 06:46:14 AM »
Hi;
We are planning to make our own plasma table. We will use the Hypertherm Sensor PHC.
The target is to use the internal anti-dive function of mach3.
But this function diables only the Z-Axis movement.
How we can modify the function so we can have a signal on a given output port if the movement speed goes below the percentage given in OEMCODE 82?
Or must we have a special script for this.
Any idea will be very helpful. Best Regards in advance.
Selim
Re: Different Use of Anti-Dive Function
« Reply #1 on: March 15, 2013, 07:23:30 PM »
You would need to route the LED for antidive to an output by using a simple brain. That way when the Antidive turns ON it creates and ouput signal to hook to your PHC unit.
