Hello Guest it is November 12, 2026, 09:03:16 PM
Author Topic: Reading data from outside, generating G code and executing it  (Read 9084 times)
I have a need to read data from outside system generating x y z coordinates, generating G code line, executing it in MACH and repeating this loop.
Can somebody point me in the right direction.
Re: Reading data from outside, generating G code and executing it
« Reply #1 on: March 31, 2013, 10:34:56 PM »
ok, have your outside source write a plain text file of coordinates, (or what ever else).
open/read that file into your plugin, process your lines into G-code, push that into
a cstring block. Push that block into the Gcode editor via mach3 calls, then run the code.....
« Reply #2 on: April 02, 2013, 07:22:44 AM »
Thank you for your kind advice.
