Hello Guest it is October 20, 2026, 10:46:34 PM
Author Topic: Ballscrew End Machining  (Read 110354 times)
Re: Ballscrew End Machining
« Reply #20 on: July 16, 2013, 06:31:06 PM »
For annealing, wrap a water soaked towel where you want to stop the heat treatment and use an induction heater.
For turning, bore a set of soft jaws and if the turned section is longish run it with a centre.
Offline derek
  •  200 200
« Reply #21 on: July 16, 2013, 07:03:31 PM »
On rolled ball screws is the exterior concentric with the lands? I was always under the assumption that you needed to indicate the screw where the ball rides.
Derek
« Reply #22 on: July 16, 2013, 08:57:04 PM »
I have checked several rolled screws and found that the OD is definitely NOT concentric with the ball tracks. Some mfgs even state this in their specs. (IIRC)
I like the split bushing deal RICH, but I would still put it in a 4 jaw and indicate the ball races true .... just to be certain.
I also found that you can not expect the OD of the ballnut (even in a precision ground assy) to be exactly concentric.
The only true way I know of is to take the time (pita) to dial in the race ways.
Russ
« Reply #23 on: July 16, 2013, 09:46:09 PM »
It makes sense that the od is not concentric. Its metal that pushed up when the rollers pressed the grooves into the shaft.
