Hello
Guest
it is
November 13, 2026, 07:42:51 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
VB and the development of wizards
thread wizard modification
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: thread wizard modification (Read 6960 times)
valmet58
11
on:
March 11, 2013, 09:46:15 PM »
i want to add comments line in the gcode generated by the thread wizard at the beginning of the gcode.. example ( gcode generated by !!!!!!!! wizard )
what command do i use ?
thanks
Logged
Kenneth
279
Re: thread wizard modification
Reply #1 on:
March 12, 2013, 04:41:12 AM »
if you're editing the code manually, you do just that.
don't think you can get the info from mach3 as to which
wizard. anything you put in () will be displayed in the
Error/Status display.
g0 x1 y1 ( gcode generated by thread wizard )
g......
Logged
Kenneth
Print
Pages:
1
Go Up
« previous
next »
