Hello Guest it is November 13, 2026, 12:39:54 PM
Author Topic: Z Axis Creeping after Feed Hold  (Read 11881 times)
« on: March 11, 2013, 11:16:35 AM »
Pressing "Feed Hold" and jogging away to clear chips, I press the "Cycle Start" to resume and noticed the Z axis starts creeping (0.001" every 2 or 3 seconds) back to home position. No issues with the X or Y axis. I've duplicated this issue several times to verify. As long as I don't use Feed Hold everything works ok. Using Gerry's 2010 screenset, licensed V.066, Gecko 540 driver.  Any suggestions?
Re: Z Axis Creeping after Feed Hold
« Reply #1 on: March 11, 2013, 01:11:37 PM »
What are you using to jog with?  I had a similar problem with a bad Xbox controller.
John Champlain
« Reply #2 on: March 12, 2013, 04:54:28 AM »
Using the PC keyboard. The problem on happens after a feed hold command. Did a search on this forum and there are several threads with feed hold problems that resulted positioning problems. Seems to be a bug in Mach 3.
« Reply #3 on: March 12, 2013, 06:45:44 AM »
Please link to these posts.
Also please attach your xml.
« Reply #4 on: March 12, 2013, 07:24:47 AM »
Hood, Do a forum search on "Feed Hold" and you will find several threads. Using a X axis sufacing wizard written by Kirk that is included with Mach 3. The gcode looks ok.  As I said... as long as the Feed Hold command isn't used it runs ok.
« Reply #5 on: March 12, 2013, 07:55:16 AM »
I fear a search for "Feed Hold" will bring up  more than one or two posts  so please attach a link to the ones of specific interest to save me time ;)
