Hello Guest it is November 13, 2026, 09:36:49 AM
Author Topic: Trouble- Mach seems to work, motors not responding  (Read 11614 times)
« on: March 10, 2013, 04:50:10 PM »
Howdy!  I've been running my cnc mill with Mach3 since 2009, then today I could not get any of the stepper motors to respond. Mach shows movement on the screen, but X,Y, and Z will not move. To my knowledge, nothing has been changed. I still hear the motors are powered up-All connections seem to be in place. I've run out of ideas. I rolled the computer back to last month, when all was fine.
Not sure if there was a driver update, or a component failure. Driving me nuts. Anybody have this happen? Any suggestions for things to check are most appreciated.
Mine is a Joe's cnc 4X4 Hybrid- three axis machine X, A+Y ganged, Z. Hobby cnc configuration.. Help, please!!! ;)
« Last Edit: March 10, 2013, 04:51:48 PM by Rich Rice »
Re: Trouble- Mach seems to work, motors not responding
« Reply #1 on: March 10, 2013, 05:09:26 PM »
Sounds like your hardware may be at fault, loose connections or similar. I know you said you checked that but if Mach is moving the DROs when you jog then it sounds like that is the problem.
If you have a scope you can check at the port, if you dont then you could check the Direction pins with a voltmeter. Connect the meter between a dir pin and a Gnd pin on the parallel port then jog the axis one way then the other, the voltage should go between 0v and 5v or vice versa.
« Reply #2 on: March 10, 2013, 05:47:17 PM »
Thank you for the advice. It's very cold out there now, as night is rapidly approaching. I will open up the controller box and see what it looks like in the morning. I had a suspicion it would be wiring or component failure, but when all four motors are energized, yet immobile- it seems like a communication problem. Definitely appreciate your help!  ;)
Rich
« Reply #3 on: March 10, 2013, 06:29:36 PM »
I would start at the back of the computer first, remove cable and check directly on port.
« Reply #4 on: March 11, 2013, 07:35:03 AM »
Well, it appears that Mach is configured and functioning properly, I'm trying to get the ambition to go back out there- but it's cold, dark, damp, and very hard to reach.. I spent most of the day fooling with it yesterday, then several trips there overnight to try different things. I get nervous poking around in sensitive electronic equipment with a meter, as I have a history of compounding electronic problems by trying to measure things I should not- I've ruined a few guitar amps by doing stuff like that, electronics is not my strongest suit. Years ago I took a college course in electronics, butt it did not relate to what I wanted to learn about- and the instructor was a design engineer for Motorola, so the course was above my level right from the start.. Now I know just enough to be dangerous. I worked as an electrician for many years, but electronics is a different field. Hope I don't make things worse...
