Hello
Guest
it is
November 13, 2026, 10:00:25 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Problems running Screen4 on XP SP2 machine
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Problems running Screen4 on XP SP2 machine (Read 10312 times)
titchener
88
on:
March 07, 2013, 07:13:18 PM »
I'm bringing up a Mach3 controlled lathe using an XP machine with SP2 loaded.
Mach3 runs fine on it but I need to tweak the screen and when I try to run Screen4 on the machine it craps out after loading the screen.
It puts up a bunch of error message boxes but they don't have any message in them so I can't tell what wrong.
The machine is pretty stripped down with hardly any other apps on it and screen4 runs fine on my office machine.
I need to be able to run screen4 right on the machine as I need to tweak some of the hotkey settings and so I need to run right on the machine that has the ipac based machine controller on it.
Do I have to put an additional runitime library or dll to allow screen4 to run on the machine?
Logged
ger21
6,295
Re: Problems running Screen4 on XP SP2 machine
Reply #1 on:
March 07, 2013, 07:51:17 PM »
In Screen4, click on Defaults, and point it to your Mach3 installation folder. Each of those message boxes is because it can't find a bitmap.
Logged
titchener
88
Reply #2 on:
March 07, 2013, 08:23:53 PM »
Thanks Gerry, i did install mach to a different directory name so that was the problem.
Logged
Print
Pages:
1
Go Up
« previous
next »
