Hello Guest it is October 31, 2026, 02:03:10 PM
Author Topic: Mach3 running on Windows 8/Microsoft Surface Pro tablet  (Read 20990 times)
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« on: March 07, 2013, 04:30:22 PM »
Just for fun I thought it would be interesting to see if Mach 3 would run on the Windows Surface Pro tablet I just got. Since this table runs the full version of Windows 8 and has a USB port it seemed like it would likely work. Mach 3 installed without a hitch. Since Windows 8 is more strict about using signed drivers some hoops had to be jumped through and a beta driver and plug in from Warp9 had to be used.
A tablet like this may not make for the most practical Mach3 PC but it is fun and I think it will be a neat to take to shows to run a machine with it.
You can find a short video at: http://www.youtube.com/watch?v=JBl9Qk7rIas
Happy machining , Jeff Birt
Re: Mach3 running on Windows 8/Microsoft Surface Pro tablet
« Reply #1 on: March 07, 2013, 06:01:41 PM »
Very nice Jeff!
« Reply #2 on: March 26, 2013, 10:12:46 AM »
Thanks for the info, I will watch the video you put in and I will apply it to my tablet.
« Reply #3 on: March 26, 2013, 11:28:32 PM »
Just for fun I thought it would be interesting to see if Mach 3 would run on the Windows Surface Pro cheap tablet I just got. Since this table runs the full version of Windows 8 and has a USB port it seemed like it would likely work. Mach 3 installed without a hitch. Since Windows 8 is more strict about using signed drivers some hoops had to be jumped through and a beta driver and plug in from Warp9 had to be used.
I am sorry it didnt work for me, i guess i need a new tablet
« Reply #4 on: October 30, 2013, 08:19:00 PM »
I just installed Mach on my laptop running windows 8 32 bit. I am having some issues with the machine getting off center and or remembering previous tool paths. I had no issues when running on windows 7. My old computer crashed and the new one that I purchased has windows 8. Loaded Mach and I am having issues with tool paths created under windows 8. However, if I run a saved project that was created before the crash on windows 7 now on the computer with windows 8 I have no issues. Have any thoughts?
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #5 on: October 30, 2013, 08:26:17 PM »
That sounds like a CAM issue not a Mach3 issue. How are you creating your GCode? What post processor are you using?
« Reply #6 on: October 30, 2013, 08:34:11 PM »
I create in Aspire 4.0. And then save tool path files to MACH 2/3 ATC ARCS inches. Maybe I will look for an update for Aspire.
« Reply #7 on: October 30, 2013, 09:39:57 PM »
Aspire isn't the problem. What kind of issues are you seeing?
