Hello Guest it is October 05, 2026, 11:32:40 AM
Author Topic: "Allow wav files"  (Read 17614 times)
"Allow wav files"
« on: March 07, 2013, 12:45:37 PM »
In the Mach3 general logic configuration screen a checkbox is present to "allow wav files"   also, "allow speech"
I have an application that could benefit from playing .wav files for at different times during a part program.  Is that the intent of these functions?  Is there any documentation on these?
Re: "Allow wav files"
« Reply #1 on: March 07, 2013, 04:53:11 PM »
Yes and YES, Mach3 programers guide.
« Reply #2 on: March 07, 2013, 06:37:06 PM »
OK, so how does "allow wave files" in the setup tie into the sub playwave ?  Playwave does not function without the box checked?
Is "allow speech" something else?
« Reply #3 on: March 07, 2013, 06:50:23 PM »
Turn on the allow wave and allow speach.
From a Mcode  add in the code you want to do.
Playwave plays a Soundfile that you define
Speak uses the window speak function to say the words you defined in the call.
It is in the Mach3 macro programmers manual.
« Reply #4 on: March 07, 2013, 08:34:34 PM »
Thank you sir.
Offline dude1
  •  1,253 1,253
« Reply #5 on: March 08, 2013, 02:20:54 AM »
could you give more info not sure how to do this
« Reply #6 on: March 08, 2013, 09:07:08 AM »
Offline dude1
  •  1,253 1,253
« Reply #7 on: March 08, 2013, 01:40:46 PM »
i have seen all of that stuff but how do i put it into a macro, tool change macro, end of program macro and fault macro
« Reply #8 on: March 09, 2013, 10:35:37 AM »
I would go to the video section of this website and watch the one on macros.
« Reply #9 on: March 09, 2013, 10:54:39 AM »
First you start off learning simple CB programming then you expand your skills and modify your running macros.
Just a thought, (;-) TP
