Hello
Guest
it is
November 22, 2026, 02:39:27 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
Delay in G-code - can't seem to eliminate it
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Delay in G-code - can't seem to eliminate it (Read 22771 times)
Chaoticone
5,624
Precision Chaos
Re: Delay in G-code - can't seem to eliminate it
Reply #10 on:
March 07, 2013, 08:44:37 AM »
Post up your XML and g code and I will take a look in a little bit. It may be a few hours as I'm going to a fab shop to have some pieces bent.
If you could see the things I have in my head, you would be laughing too.
shobley
25
Reply #11 on:
March 07, 2013, 08:56:52 AM »
The GCode I posted at the start, the XML I'm unsure of, is this the configuration file for Mach3?
Chaoticone
5,624
Precision Chaos
Reply #12 on:
March 07, 2013, 09:05:42 AM »
Yes, it will be in the C:/Mach3 folder and will have the .xml file extension. There may be several so be sure to choose the one you use on your machine and when you upload it make sure it has a unique name.
Print
Pages:
1
2
Go Up
« previous
next »
