Hello Guest it is November 22, 2026, 02:39:26 PM
Author Topic: Delay in G-code - can't seem to eliminate it  (Read 22770 times)
« on: March 06, 2013, 10:09:13 AM »
I'm not in front of the machine right now, but I've been having a problem recently with a 6-8 second delay before the machine starts to cut.
In the following G-code:
(Toolpaths used in this file:)
(center2_pocket)
(center2_cut)
(Tools used in this file: )
(1 = End Mill {0.125 inch})
N110G00G20G17G90G40G49G80
N120G70G91.1
N130T1M06
N140 (End Mill {0.125 inch})
N150G00G43Z0.8000H1
N160S12000M03  << This line waits
I'm assuming it is a "spin-up" delay for the spindle, but I've set everything back in Mach3 to 0.
I don't see anything in the preceding G-code that would override the values in the settings - does anyone have any ideas why it is still waiting?
Steve
Re: Delay in G-code - can't seem to eliminate it
« Reply #1 on: March 06, 2013, 11:00:38 AM »
Close down Mach3 and try it again. Go back and double check for the Spinup delay. What is the next line AFTER the M3 call?
Just a thought, (;-) TP
« Reply #2 on: March 06, 2013, 11:22:02 AM »
It's been doing it for several days now, so I don't think restarting is the issue.
Good idea on the G-code though - there's the rest of it...
N160S12000M03
N170(Toolpath:- center2_pocket)
N180()
N190G94
N200X0.0000Y0.0000F50.0
« Reply #3 on: March 06, 2013, 12:17:07 PM »
I guess the easiest thing to do would be to delete the M03 command from the G-code processor definition - I start the spindle manually so I don't really need it.
« Reply #4 on: March 06, 2013, 12:47:30 PM »
Have you rechecked the value for the M3 delays in config??
(;-)TP
« Reply #5 on: March 06, 2013, 12:48:57 PM »
I will do that again, I was pretty sure that they were all set to 0.
When I get back tonight I will take a look.
« Reply #6 on: March 06, 2013, 01:18:16 PM »
Also you may want to take a peak at what CODE is actually in your M3.
Has it ALWAYS done this??
« Reply #7 on: March 06, 2013, 02:17:48 PM »
Not sure what you mean - how would I check that?
I thought the G-Code was pretty much the lowest level.
Steve
P.S. I recently went from a router to a spindle, and I played with the settings. At the same time I moved to a different G-Code generation processor - so before both of those changes everything was fine.
« Reply #8 on: March 06, 2013, 02:32:24 PM »
Open the vb editor in Mach, (operator, VB script editor), file, open and browse to your mach 3 folder, macros, your profile, m3.m1s
« Reply #9 on: March 07, 2013, 08:28:54 AM »
The M3 code was "SpinCW()" - or something very similar. No timing commands.
I checked the values for delay in Mach3 and they all seem to be 0 - is there a place I may have missed?
