Hello Guest it is November 13, 2026, 09:39:54 PM
Author Topic: How to set the feedrate with a button  (Read 17178 times)
« on: March 05, 2013, 03:35:36 PM »
I want to set a new feedrate in the middle of a running program with a button.
Example:
The feedrate is a 1000mm/min in the middle of running program.
When i push a button (make in a new screen) the feedrate must be 10 mm/min.
When i push the button again the feedrate must be previous feedrate.
All this without stopping the running program.
Re: How to set the feedrate with a button
« Reply #1 on: March 05, 2013, 03:58:14 PM »
This should get you started.
'Macro to toggle feedrate +/- 10
 If  Getuserled(2000) = 0 Then
SetDro(18, (GetDro(18)+10))
SetUserLed(2000,1)
Else
SetDro(18,(GetDro(18)-10))
SetUserLed(2000,0)
End If
End
« Reply #2 on: March 05, 2013, 06:59:50 PM »
SetUserLed(2000,1)
Else
SetUserLed(2000,0)
End If
End
Hey TP, wouldn't that be .......
'Macro to toggle feedrate  BETWEEN  10 and 1000
               ... SetDro(18, (GetDro(18)*.01))
       and ....  SetDro(18, (GetDro(18)*100)) ... ?
Just guessing,
Russ
« Reply #3 on: March 05, 2013, 08:28:43 PM »
WOOPS I can't read very well I guess. Need new glasses. But you can see from the bad example how to do the function (;-) I Just need to take a math class or reading class to finish it out.
Thanks Russ, (;-) TP
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #4 on: March 06, 2013, 03:28:58 AM »
A little caution here guys with where you are so far. Feedrate is 1000. You press the button and feedrate drops to 10. But what happens if a gcode F1000 happens to come along? You press the button again expecting a feed of 10 but you get a feed of 100,000.
Ian
« Reply #5 on: March 06, 2013, 05:17:54 AM »
Thanks for the reply`s.
@Striling,
Nice one!
But there is another issue .
The feedrate is not always 1000mm/min.
I can also be a other value.
« Reply #6 on: March 06, 2013, 06:16:36 AM »
new to this so don't try without drycutting. but would it be something like this;
If GetOEMDRO(Don’t know #) = 0 Then
SetOEMDRO(?, (GetOEMDRO(?)*.01))
Else
SetOEMDRO(?,(GetOEMDRO(?)*100))
End If
End
Kenneth
« Reply #7 on: March 06, 2013, 06:27:53 AM »
TP, you did all the work, I just caught a typo. Couldn't have done it without ya. :)
Russ
Good point Ian .... real good !
« Last Edit: March 06, 2013, 06:33:14 AM by Overloaded »
« Reply #8 on: March 06, 2013, 06:30:30 AM »
Doesn't matter what the FR is, it just gets multiplied by .01 then back to the originally called FR by the *100.
« Reply #9 on: March 06, 2013, 10:51:00 AM »
normally I would capture the current FR and then ASK what you wanted for a new feedrate.
Just as easy to TYPE in the wanted feedrate in the DRO.
Russ, I could have sworn I read it as, want to reduce it by 10 IPM and then back to normal.  (;-)
« Last Edit: March 06, 2013, 10:53:00 AM by BR549 »
